1 di 5
Aim X Log compact Datalogger
SKU: XLOG
Prezzo regolare
£460.00GBP
Prezzo regolare
Prezzo di vendita
£460.00GBP
Powered by Shopify Planet
X Log
Compact, powerful, reliable
X Log is an extremely powerful and compact datalogger..
  • ECU stream CAN: K-line or RS232 connections
  • GPS: four constellations (GPS, GLONASS, BeiDou and Galileo), 25 Hz, with less than
    half a meter precision.
  • internal 6 axis inertial platform
  • Expansions:
    • ACC 2: Analog inputs
    • LCU-One S: Lambda controller
    • SmartCam 3 series: Motorsport cameras
Then, it features:
  • Integrated Wi-Fi and Bluetooth
  • Long lasting Lithium Battery and connection for an external 8-16V battery
  • 4 GB internal memory
  • Removable USB Type-C key
  • Waterproof (IP67)
Then, it features:
  • Waterproof (IP67)
2 Log
2 Log
ECU Log
Aim X Log Compact Datalogger
  • Inertia platform: 100 Hz 6 axis
  • GPS: 25 Hz
  • Wifi: Built in
  • Bluetooth: Built in
  • ECU Connections: CAN, RS232 or K-Line to 1,000 + Industry leading ECUs
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • External Power: 0-15 V
  • Connectors: 5 pins binder 712, 7 pins binder 712, USB Type-C
  • Memory: 4GB internal + removeable USB Type-C key
  • Material: PA6 + 30% glass fibre reinforced
    • X Log
    • Mini USB drive 16gb
    • Either CAN/OBDII or CAN/RS232/EXT. Power 2m cable
    • USB 2.0 A-Type C-Type 2m cable
      X Log
      • Expansions:
      Then, it features:
      • Waterproof (IP67)
      Then, it features:
      • Waterproof (IP67)
      2 Log
      2 Log
      ECU Log
      • GPS: 25 Hz
      • Wifi: Built in
      • RPM Input: 1
      • Push Button: 1
      • Status LED: 1
        • X Log
