1 di 2
AiM T12 Exhaust Gas Temperature Sensor (EGT) for Kart
SKU: S-T-EGT-T12
Prezzo regolare
£70.00
Prezzo regolare
Prezzo di vendita
£70.00
The AiM exhaust gas temperature (EGT) kart sensor accurately measures exhaust gas using a thermocouple placed in the exhaust header pipe for faster data reading and designed to operate with all MyChron kart dash/data loggers.
EGT Sensor T12 Yellow mignon plug 2 pins
Suitable for all Mychrons 4 & 5 S 2T
The AiM exhaust gas temperature (EGT) kart sensor accurately measures exhaust gas using a thermocouple placed in the exhaust header pipe for faster data reading and designed to operate with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4).
When running the thermocouple cable through the chassis, ensure to keep it as far as possible from other cables, such as RPM cables or receivers, to minimise interference.
The exhaust gas temperature sensor uses a two-pin mignon plug
Different fitments available, including KZ /KF kart engines (T12 Rotax, X30, OK)
Please note, if you want to monitor both exhausts (EGT) and under the plug, or two exhaust (EGT) or two under plug temperatures (CHT), you will need to use the Double Temperature patch lead, which is fitted with 2 Mignon yellow plugs. These cables are available in the Accessories Tab.
  • Temperature Working Range: 0-1000°C (32-1832°F)
  • Cable: Compensated
  • Cable Length: 250mm (9.8")
  • Thread: M12 x 1.5
  • 2 pin Male Connector
  • 1 x AiM T12 (EGT) Exhaust Gas Temperature Sensor
  • Thread: M12 x 1.5
