Aim Spark Plug Inductive RPM Bike Adaptor
SKU: MXL-RPM-IP
- Prezzo regolare
- £75.00
- Prezzo regolare
- Prezzo di vendita
- £75.00
- Prezzo unitario
+ IVA (solo Regno Unito)
Spark Plug Inductive RPM Adaptor
The Aim RPM Adaptor has been designed for single cylinder 2 or 4-stroke engines.
Key Features:
The Aim spark RPM adaptor has been designed for installation on single cylinder 2 or 4-stroke engines. It is a filter that converts the RPM signal sampled by induction from the spark plug into a square wave signal. The image below shows the signal sampled by induction on the left and the square wave signal on the right. |
To install the adaptor connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. |
Our mission is to help educate you and enable you to get the most out of your Aim data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
The drawing below shows the adaptor correctly installed.
Aim Spark Plug Inductive RPM Adaptor
Key Features:
To install the adaptor connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. The red cable is labelled 9-15 VDC to a +12V output (the battery positive pole for example). The blue cable labelled RPM to Aim device RPM input. |
What's In The Box
