AiM Solo 2 & Solo 2 DL Mains Charger & Power Lead UK Plug Motorcycle
SKU: SOLO-12V-UK
- Prezzo regolare
- £50.00
- Prezzo regolare
- Prezzo di vendita
- £50.00
- Prezzo unitario
The AiM Solo 2 & Solo 2 DL EU mains charger & power lead is used for charging from UK mains power.
5 pin - 712 male binder connection | UK 3-pin plug |
Suitable for Solo 2 & Solo 2 DL | 12V |
Solo 2 / Solo 2 DL EU Power Cable
The AiM Solo 2 & Solo 2 DL mains charger and power lead. Motorsport UK 3-pin connection plug for charging from UK mains power.
The lead features a 5-pin 712 male binder connection and a 3-pin UK plug for mains connection.
- UK mains charger - 3 pin
- 5 pin 712 - male binder connection
- 12V
- UK mains charger & power lead
The AiM Solo 2 & Solo 2 DL EU mains charger & power lead is used for charging from UK mains power.Key Features :
The AiM Solo 2 & Solo 2 DL mains charger and power lead. Motorsport UK 3-pin connection plug for charging from UK mains power.The lead features a 5-pin 712 male binder connection and a 3-pin UK plug for mains connection.
- 12V
