1 di 1
AiM Solo 2 Dash / Steering Wheel Mount
SKU: UP-SOLO2
Prezzo regolare
£17.00
Prezzo regolare
Prezzo di vendita
£17.00
The Solo 2 dash/steering wheel mount is an easy and permanent fixture for mounting your Solo 2.
Solo 2 dash/steering wheel mount 2mm thick stainless steel
Solo 2 / Solo 2 DL Spare Backing Plate
The Solo 2 dash/steering wheel mount is ideal if you want a permanent and easy fixture.
2mm in raw stainless steel
Other options are available to assist with this product, see the accessories tab for more options.
  • Dash/steering wheel mount
  • 2mm raw stainless steel
  • Solo 2 dash/steering wheel mount
