AiM SmartyCam HD 2.1 Display Glass Replacement Kit
SKU: SM-R-K2
- Prezzo regolare
- £30.00
- Prezzo regolare
- Prezzo di vendita
- £30.00
- Prezzo unitario
Replacement glass for the AiM SmartyCam HD 2.1 camera, providing anti-glare and scratch protection.
Fits SmartyCam HD 2.1 | Ideal replacement or spare |
Anti-scratch protection |
AiM SmartyCam HD 2.1 Glass Replacement Kit
The AiM glass replacement is an anti-glare, anti-scratch replacement lens to fit the SmartyCam HD 2.1 and is the same as supplied with the camera. The kit features Schott B270 glass and an O ring OR30X1.
It is ideal for replacing damaged protectors or for keeping as a spare.
It fits SmartyCam HD 2.1
Scratch-resistant
Anti-glare
Includes O ring seal and surround fixing screws
- Fits SmartyCam HD 2.1
- Scratch-resistant glass
- Anti-glare
- Includes O ring seal and surround screws
- Glass replacement Kit - For SmartyCam HD 2.1
Replacement glass for the AiM SmartyCam HD 2.1 camera, providing anti-glare and scratch protection.Key Features :
The AiM glass replacement is an anti-glare, anti-scratch replacement lens to fit the SmartyCam HD 2.1 and is the same as supplied with the camera. The kit features Schott B270 glass and an O ring OR30X1.It is ideal for replacing damaged protectors or for keeping as a spare.
Scratch-resistant
Anti-glare
- Anti-glare
