AiM SmartyCam Bullet Cam GP 2.2 & 3 Connection Harness
SKU: SM-GP-1-R2
- Prezzo regolare
- £80.00
- Prezzo regolare
- Prezzo di vendita
- £80.00
- Prezzo unitario
The AiM SmartyCam GP 2.2 & 3 connection harness is the cable that is fitted between the recorder box and the bullet camera.
Suitable for SmartyCam 2.2 & 3 GP | Connection harness |
Use as a replacement or spare |
The AiM SmartyCam 2.2 & 3 GP connection harness is the cable that is fitted between the recorder box and the bullet camera.
Suitable for the SmartyCam 2.2 & 3 GP
Available in 1m, 2m, 3m, 4m
- SmartyCam 2.2 & 3 GP Connection Harness
- Lead fits between the recorder box and the bullet cam
- Available in 1m, 2m, 3m, 4m
- 1 x SmartyCam 2.2 & 3 GP Connection Harness
The AiM SmartyCam GP 2.2 & 3 connection harness is the cable that is fitted between the recorder box and the bullet camera.Key Features :
The AiM SmartyCam 2.2 & 3 GP connection harness is the cable that is fitted between the recorder box and the bullet camera.Suitable for the SmartyCam 2.2 & 3 GP
