1 di 5
AiM MyChron5 Kart Racing Steering Wheel Red/Black
SKU: M5-W-R
Prezzo regolare
£165.00
Prezzo regolare
Prezzo di vendita
£165.00
The AiM MyChron5 Kart Steering Wheel provides an ideal solution for mounting your MyChron5 and MyChron 5S dash logger.
Fits MyChron5 S & MyChron5 S 2T 3 & 6 hole fixing
Secure leather grip
Lightweight but rugged and ergonomic allows you to put your MyChron5 in the best position right in front of you.
The MyChron5 steering wheel has an anodised aluminium frame covered by chamois leather with a flat bottom and a curved top.
The Nucbuk coating around the sides maximises grip, bringing total control of the kart in your hands.
Options
Available in two colours (red/black or black) with 3/6 holes, the MyChron5 Steering Wheel is a "must-have" tool for all MyChron5 owners.
Measuring 340 x 320mm and supplied complete with mounting bracket.
  • Diameter: 340mm
  • Weight: 600g
  • Versions: Three-hole or Six hole
  • Chassis: Anodized Aluminium
  • Finishing: Koram Nabuk and Shammy Leather
  • AiM MyChron5 Steering Wheel
Secure leather grip
Options
  • Diameter: 340mm
  • Weight: 600g
