1 di 3
AiM MyChron5 S 2T Patch Lead Yellow TC Plug & Black 719 TR Plug
SKU: P-712-TC-TR
Prezzo regolare
£50.00
Prezzo regolare
Prezzo di vendita
£50.00
AiM MyChron 2T Patch Lead Yellow TC Plug & Black 719 TR Plug
AIM MyChron5 2T double temperature patch leads are suitable for the AIM 2T (2 temperature) model MyChron 5 S, MyChron 5 and older MyChron 4's.
TC plug & 719 TR plug Suitable for fitting EGT & water temperature
Compatible with MyChron 4 & 5
AIM MyChron5 2T double temperature patch leads are suitable for the AIM 2T (2 temperature) model MyChron 5 S, MyChron 5 and older MyChron 4's. These patch leads are used for connecting different temperature sensors to the dash. This links to the seven-pin (712) TEMP port on the back of the MyChron dash.
These are the sensors that may be connected with this patch lead. 1 x TC (Mignon) Plug and 1 x TR (719) Plug: Suitable for fitting 1 x Exhaust Gas Temperature (EGT) or 1 Underplug Temperature sensor and 1 x Water Temperature Sensor. This is the standard lead as supplied with 2T MyChron's.
Cable length 1.5m
  • MyChron5 S 2T patch lead with TC Plug & 719 TR Plug
  • Suitable for fitting 1 x (EGT) Exhaust Gas Temperature Sensor or an under plug sensor or 1 under plug sensor and a water temperature sensor
  • Cable length: 1.5m
  • MyChron5 S 2T Patch Lead TC Plug & Black 719 TR Plug
Cable length 1.5m
