AiM MXT 1.3 Strada 10" TFT Digital Display with Race Icons
SKU: MXT
- Prezzo regolare
- £1,400.00
- Prezzo regolare
- Prezzo di vendita
- £1,400.00
- Prezzo unitario
AiM MXT 1.3 Strada 10" TFT Dash Display with Race Icons
10" TFT display
6 alarm RGB LEDs
10 shift light RGB LEDs
8 analogue inputs
CAN output
Configure data
Freely Configurable Pages
Flexible Alarms & Custom Street Icons
Two Digital Outputs
They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.
Camera Inputs & Mirror Camera
Integrated Shift Light Array
10" TFT display
6 alarm RGB LEDs
8 analogue inputs
CAN output
Configure data
Two Digital Outputs
- Display: 10" TFT
- Contrast: 1,100:1
- Brightness: 800cd/m
- Ambient Light Sensor: Yes
- Alarm LEDs: 6 configurable RGB LEDs
- CAN Connections: 3
- Analogue Inputs: 8 fully configurable, max 500 Hz each
- Digital Inputs: 4-speed input, lap signal, coil RPM input
- Digital Outputs: 2 (1 A max)
- Second CAN: Yes
- Internal memory: 4GB
- Body: Anodised Aluminium
- Connectors: 2 Autosport connectors + 1 Binder connector
- Power Consumption: 450 mA
- Dimensions: 278 X 135 X 43.2mm
- Weight: 1,200g
- MXT 1.3 Strada
- USB Cable
- 37 Pin Standard Harness
