1 di 2
AiM Motocross TM Racing Solo 2 DL Plug & Play Lead
SKU: TM-MX-PP
Prezzo regolare
£67.00
Prezzo regolare
Prezzo di vendita
£67.00
The AiM ECU plug & play cable has been specifically designed for TM Racing bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
TM Racing plug & play cable 7 pin - 712 male binder connection
TM Racing Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the TM Racing bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following TM Racing bike models:
SMX 450 F1 - From 2015 MX 250 F1 - From 2015
MX 450 F1 - From 2015 EN 250 F1 - From 2015
EN 450 F1 - From 2015
Example data protocols
  • Below is a pinout drawing for the TM Racing Solo 2 DL plug & play connection cable
  • TM Racing Plug & Play connection cable
