1 di 4
AiM Mirror & Reversing Camera for MX Series & PDM
SKU: MIR-CAM
Prezzo regolare
£125.00
Prezzo regolare
Prezzo di vendita
£125.00
Our AiM innovative camera will turn your dash display/dash logger into a rear view mirror or reversing camera. Ideal for sports or race cars with limited view.
Ideal for vehicles with limited view Suitable for MX Series and PDM
 5 pin male binder connection Park overlay function
 Mirror/Reversing Camera
This camera fits the AiM MX Series dash displays and loggers and our PDM with mirror camera input port.
Plug & play connection via patch lead, these are available in the options. Up to two cameras can be connected to any MX Series dash display/ dash logger to show different perspectives. A park overlay function can be activated for an additional aid when tour reverse parking.
The camera is supplied with a short lead so a patch lead is usually required for installation. (Patch cables Sold Separately)
The patch cables are available in four different options depending on your requirements: Single camera for connecting 1 x AiM reversing mirror camera. 2 x Cameras for connecting 2 x AiM reversing mirror cameras. Single RCA for connecting a single other brand camera with RCA connection. 2 x RCA for connecting 2 x other brand cameras with RCA connection.
Please Note: Long lead length for running from the front to the back of the car - AiM patch cable are 6m in length, RCA patch cable is 5m in length.
The camera is supplied with a base mount bracket for mounting to a flat surface. Mounting through a panel is also possible and a correct sixed hole is provided to faciliatae this.
  • Optical Format: 1/4 inch colour CMOS
  • TV System: NTSC
  • H-FOV: 170°
  • Pixel Array: 648 (H) x 488 (V)
  • Frame Rate: 60 fps
  • Temperature: -30/80°C
  • See the Technical Sheet in the Downloads Tab for the different patch cable drawings.
  • One mirror/reversing camera - Patch cables are sold separately
  • Flush Mount kit - Drill bit & Flush mount
  • Swan Neck kit - Rubber pad, Screws & Bracket
  • TV System: NTSC
  • H-FOV: 170°
