AiM Motorcycle IR Pick Up 712 Plug 90cm
SKU: S-IR-712-9
- Prezzo regolare
- £80.00
- Prezzo regolare
- Prezzo di vendita
- £80.00
- Prezzo unitario
The AiM Infrared Receiver is a spare or replacement Receiver that is installed on your motorcycle and receives the lap signal from the infrared transmitter.
Spare / Repalcement Reciver | 4 pin 712 connector |
The AiM Infrared Receiver sometimes referred to as an Optical Lap Reciever is installed on your motorcycle and receives lap signals from the infrared transmitter positioned at the side of the track. It just needs to be pointed to the side of the track where the transmitter is installed to be able to read the signal.
The motorcycle infrared receiver is available with a 90cm lead, it is also available with a 300cm lead for cars, although there is nothing stopping you from using the lead that best suits your requirements.
Installation
Analyse with Race Studio 3
- Binder connection Pinout:
- 1 - n.c
- 2 - GND
- 3 - V battery (7-15 VDC)
- 4 Optical Lap Signal
- IR Optical Lap Receiver 712 Plug 300cm
The AiM Infrared Receiver is a spare or replacement Receiver that is installed on your motorcycle and receives the lap signal from the infrared transmitter.Key Features :
The AiM Infrared Receiver sometimes referred to as an Optical Lap Reciever is installed on your motorcycle and receives lap signals from the infrared transmitter positioned at the side of the track. It just needs to be pointed to the side of the track where the transmitter is installed to be able to read the signal.It is also available with a 4 pin plastic plug connector.
Installation
The Infrared receiver should be fixed to your bike by fixing through the fixing hole at the top of the receiver. When fixing the receiver be sure that the eye is pointing to the side of the track where the receiver has been installed.Analyse with Race Studio 3
- 1 - n.c
- 2 - GND
