1 di 1
Hub For Universal Steering Wheel Bracket
SKU: UP-CH
Prezzo regolare
£12.00
Prezzo regolare
Prezzo di vendita
£12.00
Universal steering wheel hub mount, to fit dash logger display on the side column of a quick release steering wheel.
Key Features:
  • Universal steering mount
  • Stainless steel, raw finish
  • Free race studio 3 download
Centre Hub Mount
The universal steering hub mount has been designed to fit a dash logger display on the steering column side of your quick release steering wheel.
This is the central hub to use if you only want to mount a dash on the steering column side of your quick release.
70 & 76mm PCD 6 hole fitting covers almost all 6 bolt steering wheels.
2mm thick in raw stainless steel
The interchangeable stainless steel steering wheel button and display mounts are a stylish and cost effective solution to your mounting requirements.
The design is based around the centre hub which mounts between the steering wheel and the quick release device.
Please Note: If you have a low or no dish steering wheel, you will probably need the 3mm hub spacer to give sufficient bolt head clearance.
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today.
Unlock your potential
    AiM Hub For Universal Steering Wheel Bracket
    • 70 & 76mm PCD 6 hole fitting covers almost 6 bolt steering wheels
    • 2mm thick raw stainless steel
    Technical Sheet
    Key Features:
    Centre Hub Mount
      Whats In The Box
      Technical Sheet
