AiM EVO5 37 Pin Deutsch Harness
SKU: EVO5-H37
- Prezzo regolare
- £375.00
- Prezzo regolare
- Prezzo di vendita
- £375.00
- Prezzo unitario
The AiM EVO5 37 pin Deutsch harness is the standard harness supplied with the EVO5 Data Logger.
Suitable for EVO5 | Standard 37 harness |
4 analogue channels | |
37 pin Harness for EVO5
The AiM 90° 37 pin Deutsch harness for the EVO5 is the standard harness that is supplied with the EVO5.
This harness can be used to replace a damaged harness or for a second vehicle installation when sharing to moving a dash logger.
The standard 37 pin harness that comes with the EVO5 allows 4 inputs. If you would like to add more inputs to your race data then add this optional harness.
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
- 37 pin Deutsch Female Flying Connector
- 5 pins Binder 712 Female Connector - See table in Downloads Tab
- None ended cables - See table in Downloads Tab
- EVO5 37 Pin Deutsch Harness
The AiM EVO5 37 pin Deutsch harness is the standard harness supplied with the EVO5 Data Logger.Key Features :
The AiM 90° 37 pin Deutsch harness for the EVO5 is the standard harness that is supplied with the EVO5.This harness can be used to replace a damaged harness or for a second vehicle installation when sharing to moving a dash logger.
