AiM EVO4S Power Cable
SKU: EVO4S-PC
- Prezzo regolare
- £42.00
- Prezzo regolare
- Prezzo di vendita
- £42.00
- Prezzo unitario
The AiM EVO4S power cable is a spare external power cable for the EVO4S data logger.
712 Male 2 pin | Two flying spade connectors |
12 volts |
The AiM EVO4S is a spare external power cable for the EVO4S data logger. It has a 712 male binder that connects to the power input on the data logger. There are two flying spades (wires) connectors.
With Race Studio 3 you can also analyse all data recorded by MXG Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performance.
- 712 2 pin male binder
- Two flying spade connectors
- 9-15V
- Battery GND
- EVO4S Power Cable
The AiM EVO4S power cable is a spare external power cable for the EVO4S data logger.Key Features :
12 volts |
The AiM EVO4S is a spare external power cable for the EVO4S data logger. It has a 712 male binder that connects to the power input on the data logger. There are two flying spades (wires) connectors.Expand Your System
These are only some of the items that can be added to our EVO4S for incrementing the performance and the data acquired.Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded by MXG Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performance.Technical Specifications
- 9-15V
- Battery GND
- EVO4S Power Cable
