1 di 3
Dual Brake Pressure Mounting T-Piece Kit
SKU: S-P-DP
Prezzo regolare
£86.00
Prezzo regolare
Prezzo di vendita
£86.00
The Dual Brake Pressure Monitoring T-Piece can be used with the M10 brake pressure sensors, which have a 719 plastic binder connector to fit AiM systems or extension leads.
Suitable for M10 brake pressure sensors Dual pressure T-piece
Used for Motorsport racing, this dual brake pressure kit allows you to see:
Brake pressure
Braking points (start and end)
Driver alertness
Brake system status
  • Brake Pressure
  • Braking Points (start & end)
  • Driver Alertness
  • Brake System Staus
  • 1 x Dual Brake Pressure Mounting T-Piece
Brake pressure
Driver alertness
Brake system status
  • Brake Pressure
  • Driver Alertness
