1 di 9
Complete OTK Kart Non-Contact Throttle Sensor Kit
SKU: S-NC-T-OTK
Prezzo regolare
£160.00
Prezzo regolare
Prezzo di vendita
£160.00
The non-contact throttle position sensor kit to suit OTK kart measures the throttle pedal travel to see if the driver applies the desired percentage of throttle throughout the lap.
Suitable for OTK Karts Compatible with MyChron4 & MyChron5
4 pin 719 male binder connector Complete with brackets and fittings
The kit has been designed specifically to fit all OTK karts and comes complete with all the necessary brackets making installation very easy.
Main Functions
The magnets mount to the pedals and the sensor to the kart, with no messy wires getting in the way.
It gives an exact indication of the pedal position, measures its travel and shows all values in percentage in a 0 to 100 range.
An effortless way to evaluate a driver's behaviour and improve their performance.
Suitable for use with the AIM MyChron4, MyChron5, MyChron4 2T and MyChron5 2T Kart Dash / Data Loggers. The sensor comes complete with the patch lead required to connect the sensor to the MyChron Expansion box, the standard method of connecting it to your system.
For images on how to fit the sensor please refer to the Technical Tab.
  • The sensor comes with a 25cm patch lead with a 4 pins Binder 719 male connector
  • Binder Connection Pin:
  • 1 - Analogue signal 0-5V
  • 2 - GND
  • 3 - Not Connected
  • 4 - V reference (4.5V)
  • OTK Sensor with patch lead
Main Functions
  • 2 - GND
  • 3 - Not Connected
