AiM Brake Pressure Sensor Dash 3 3/8 24 0-100 Bar Motorcycle
SKU: S-P-B-D3-X05PSA00100B38-MC
- Prezzo regolare
- £190.00
- Prezzo regolare
- Prezzo di vendita
- £190.00
- Prezzo unitario
+ IVA (solo Regno Unito)
The AiM 3/8 24 0-100 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
3/8th 24 - 0-100 Bar | 4 pins 719 male binder |
The AiM 3/8th 24 - 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
- Supply: 8-16V
- Characterisation: 500 mV/ 0 bar 4500 mV/ 100 bar
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: 3/8 24
- AiM Brake Pressure Sensor 3/8 24 - 0-100 Bar
The AiM 3/8 24 0-100 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Brake_Pressure_Sensor_Dash_3_3_8_24_0-100_Bar_main_image.png?v=1624458104)
The AiM 3/8th 24 - 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.Whether your bike is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make real changes and identify issues quickly and precisely.
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: 3/8 24
![AiM Brake Pressure Sensor Dash 3 3/8 24 0-100 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorDash33_8240-100Bar_7296a62f-7d2f-4bba-8a55-8e2ab409064a_1445x.png?v=1617785518)
![AiM Brake Pressure Sensor Dash 3 3/8 24 0-100 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorDash33_8240-100Bar_f93ef5cb-1a6e-4c3d-8437-a920dbbd56b7_1445x.png?v=1617785518)
![AiM Brake Pressure Sensor Dash 3 3/8 24 0-100 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorDash33_8240-100Bar2_8c4dac37-8fab-41b4-8cb2-8fe55ebcdae1_1445x.png?v=1617785518)
![AiM Brake Pressure Sensor Dash 3 3/8 24 0-100 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorDash33_8240-100Bar3_17e2fdef-5529-4830-8306-7c1f7ca4f137_1445x.png?v=1617785518)
