1 di 2
AiM 719 (Plastic) Binder Plug Male
SKU: P-719-M
Prezzo regolare
£10.00
Prezzo regolare
Prezzo di vendita
£10.00
The AiM 719 binder plug 4 pin male is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system.
Suitable for AiM sensors 4 pin male plastic Binder
Ideal for adding to your system
The AiM 719 binder plug 4 pin male is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system. The plug has four pins.
Ideal for replacing broken plugs or when adding sensors to your AiM system
Fits AiM 719 cables and sensors
  • 719 Plastic Binder Plug
  • 1 x 719 Plastic Binder Plug
