AiM 14 Pin Plug and Pins (1.2 Strada MXS, MXP, MXG)
SKU: P-AMP-14-5CND7762732-CT0770520
- Prezzo regolare
- £34.00
- Prezzo regolare
- Prezzo di vendita
- £34.00
- Prezzo unitario
The AiM 14 pin plug and pins are ideal for the MX Strada 1.2 loggers if you're in need of a replacement or just to keep them as spares.
Suitable MX Strada Series 1.2 | 14 pins, One plug |
Ideal for replacement or spares | |
The AiM 14 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable for MX Series Strada 1.2
- AMP Plug
- 14 Pins
- AiM 14 Pin Plug & Pins for MX Series Strada 1.2
The AiM 14 pin plug and pins are ideal for the MX Strada 1.2 loggers if you're in need of a replacement or just to keep them as spares.Key Features :
The AiM 14 pin plug and pins are ideal if you need a replacement or to keep them as spares.Suitable for MX Series Strada 1.2
- AMP Plug
- 14 Pins
