1 di 3
AiM 10" TFT PDM Display Screen
SKU: DISPLAY-10-XC1D10000
Prezzo regolare
£545.00
Prezzo regolare
Prezzo di vendita
£545.00
The AiM 10" TFT PDM Display Screen is specifically designed to fit the PDM08 & PDM32 Power Distribution Modules.
Key Features:
  • 10" TFT display
  • 10 Configurable RGB LEDs
  • 6 Configurable Alarm RGB LEDs
  • For use with PDM kits
  • User configurable layout
  • Replaces all gauges & wiring lights
  • Free race studio 3 download
The AiM 10" dash display is suitable for replacing all of the dashboard gauges and warning lamps. It has a fully configurable display and offers a range of layouts.
The screen can also double up as a mirror by using a separately available camera. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views.
High Contrast TFT Display
Designed for use with the AiM PDM kits
User configurable display with many layout options
Replaces all dashboard gauges and warning lights in one unit.
Compare AiM Dashes
AiM 10" TFT PDM Display Dash
  • Display: 10" TFT
  • Display Resolution: 1280 x 480 pixels
  • Contrast: 1100:1
  • Brightness: 800cd/m2
  • Alarm Display Icons: Yes freely configurable
  • Shift Lights: 10 configurable RGB LEDs colours
  • Alarm LEDs: 6 configurable RGB LEDs colours
  • Connectors: 1 Rosenberger
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Dimensions: 278 x 135 x 37,2mm
  • Weight: 1035g
      Key Features:
      • 10" TFT display
      Compare AiM Dashes
      Technical Specifications
      • Display: 10" TFT
      • Contrast: 1100:1
      • Weight: 1035g
      Whats in The Box
