דלג לפרטי המוצר
1 שֶׁל 5
Yamaha YZF-R6 (YEC included) AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-YAM-4-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256920CS-X47SOLO2DL02
מחיר רגיל
£2,210.00
מחיר רגיל
מחיר מבצע
£2,210.00
Yamaha YZF-R6 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
Database with more than 4,000 tracks worldwide Yamaha ECU connection cable
K-YAM-4-SM-CAM
SmartyCam 3 GP Features:
Yamaha YZF-R6 (YEC included) - 2004-2005
Powerful Combination
SmartyCam 3 GP
Automatic Start/Stop
K-YAM-4-SM-CAM
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Yamaha YZF-R6 Plug & Play connection cable
  • Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 2 washers M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
K-YAM-4-SM-CAM
SmartyCam 3 GP
K-YAM-4-SM-CAM
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 2 spacers
  • 2 washers M6
  • 4 washers M6
  • 2 washers M4
