Yamaha YZF-R1 (2004-2008) & YZF-R6 (2006-2016) AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-YAM-2-V0256919CS-X47SOLO2DL02
- מחיר רגיל
- £710.00
- מחיר רגיל
- מחיר מבצע
- £710.00
- מחיר ליחידה
- לְכָל
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Yamaha ECU connection cable |
This kit has been specifically designed for Yamaha bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.
Yamaha YZF-R1 (YEC included) - 2004-2008 | Yamaha YZF-R6 (YEC included) - 2004-2016 |
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Yamaha YZF-R1 & YZF-R6 plug & play connections cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Yamaha Connection Cable
- Bracket
- 2 spacers
- 2 self-locking nuts M6
- 4 washers M6
- 2 self-locking nuts M4
- 2 washers M4
- 2 Allen screws with rounded head M6 x 60mm
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Yamaha bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The plug & play cable currently fits the following Yamaha bike models:Yamaha YZF-R1 (YEC included) - 2004-2008 | Yamaha YZF-R6 (YEC included) - 2004-2016 |
The Yamaha ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
- 2 spacers
- 4 washers M6
- 2 washers M4
