דלג לפרטי המוצר
1 שֶׁל 1
Suzuki GSX-R AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: SUZ-B
מחיר רגיל
£60.00
מחיר רגיל
מחיר מבצע
£60.00
The AiM Suzuki motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Suzuki bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
Suzuki Solo 2 & Solo 2 DL Bracket
The Suzuki GSX-R bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer onto your bike.
Please Note: See below to check the bracket is compatible with your bike.
Also available is our Suzuki plug & play cable for the following bike models: (Sold Separately)
GSX-R600 - 2006-2019 GSX-R750 - 2006-2019
GSX-R1000 - 2005-2019 GSX-R1300 Hayabusa Gen.2 - 2008-2016
GSX-R1000 L7 - 2017 onwards
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 GSX-R750 - 2001-2019
GSX-R1000 - 2001-2004 and 2009-2019
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
Example data protocols
  • Specifically designed Suzuki bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
