Super B Touch Display ( Displays Battery, Voltage, Current & Status )
SKU: TD
- מחיר רגיל
- £200.00
- מחיר רגיל
- מחיר מבצע
- £200.00
- מחיר ליחידה
- לְכָל
+ מע"מ (בריטניה בלבד)
![superb lithium batteries](https://cdn.shopify.com/s/files/1/0214/9392/files/superbLogo.png?v=1710418318)
The Super B touch display is a smart battery meter that can measure and display the voltage, current, state of charge and time to go of your lithium battery. This gives you 24/7 insight in the available capacity of the battery.The touch display is suitable for 12 volt systems of the Nomia and Epsilon and can be set up in 6 different languages: English, French, German, Dutch, Italian and Spanish.
PRODUCT SPECIFICATIONS
![superb app](https://cdn.shopify.com/s/files/1/0214/9392/files/codescan.png?v=1710425607)
The Super B touch display is a smart battery meter that can measure and display the voltage, current, state of charge and time to go of your lithium battery. This gives you 24/7 insight in the available capacity of the battery.The touch display is suitable for 12 volt systems of the Nomia and Epsilon and can be set up in 6 different languages: English, French, German, Dutch, Italian and Spanish.Specifications
Quickstart Guide
Mobile App
![Super B Touch Display ( Displays Battery, Voltage, Current & Status ) - AimShop.com](http://www.aimshop.com/cdn/shop/files/976-Touch_display_1445x.jpg?v=1710499356)
