דלג לפרטי המוצר
1 שֶׁל 2
Super B BCI Battery Communication Interface ( Nomia & Nomada )
SKU: BCI
מחיר רגיל
£235.00
מחיר רגיל
מחיר מבצע
£235.00
superb lithium batteries
BCI
The Battery Communication Interface (BCI) is a device that gathers data from multiple Super B lithium batteries and represents them as one single battery system.
  • Product Features
  • Control pre-charge functionality. Therefore, an additional contactor
    and resistor is needed tailored to the application
  • Protocol conversions (depending on BCI software version)
  • Control charger by CAN or charge enable signal (depending on BCI software version)
  • Manage the heaters of Super B Li-ion batteries outfitted with heating elements
Intended Use
Potential applications to use the BCI in combination with Li-ion batteries from Super B are:
• Off grid applications
• Marine applications
• Medium for (renewable) energy storage (traction)
• Battery for vehicles.
Depending on the application it can be necessary that additional components are used to assure that the installation is compliant with the applicable regulations. See chapter 5.6 for information on electrical installations.
The BCI is sold as a single device, the customer is expected to source necessary components for protecting the Li-ion batteries. Super B cannot be held responsible for installations made by the customer.
Super B also offers the option of supplying the complete installation. This can be a standard solution or a custom solution. The standard solution can be found on our website or by contacting sales. The custom solution needs to be aligned with your sales and application engineering contact.
If this manual does not cover or address your application, please contact Super B. Only qualified personnel may install and perform maintenance on the complete system - always refer to chapter 1 of this manual for safety guidelines.
The boundaries of the BCI use, as described in this manual should always be upheld. The BCI may not be used in medical, or in aviation related applications. The BCI may not be used for any purposes other than described in this manual. Using the BCI for any other purposes will be considered improper use and will void the warranty of the product. Super B cannot be held responsible for any damage caused by improper, incorrect, or unwise use of the product. Please read and understand this entire manual carefully before using the product
superb app
User Manual
CAD File
BCI
  • Product Features
Intended Use
Mobile App
superb app
User Manual
CAD File
