AiM Solo 2 DL Motorcycle Plug & Play Data Logging Kit
SKU: SOLO2-K-YAM-4-ACC-SUS-POT-75-SUS-POT-150-S-P-B-M10-BP-DB-P-719-719-5-P-719-719-5-P-719-719-10
- מחיר רגיל
- £1,795.00
- מחיר רגיל
- מחיר מבצע
- £1,795.00
- מחיר ליחידה
- לְכָל
+ מע"מ (בריטניה בלבד)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/7_7f2fa98f-5fc2-4c4e-a4c5-44639f10c330.png?v=1700063221)
Solo 2 DL
The Solo 2 DL can handle an ECU input with a CAN expansion port that you can connect a SmartyCam to.
The data you record typically includes RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel).
Bike-Specific Plug & Play Cable
The kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/8_e4d703fc-a51a-423e-a445-797cb1a8be43.png?v=1700063221)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/BIKE_PLUG_PLAY_DASHES.png?v=1700063228)
Brake Pressure
Sensor
Brake pressure sensors are used to measure how much force is applied by the rider to the brake, when combined with suspension potentiometers, you can get a greater understanding of your bike setup.
Suspension Potentiometer
The suspension potentiometer is used to measure the travel of the suspension forks on your motorbike and therefore helps to understand your suspension setup.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/10_a227c6e9-03c8-4246-bccd-931f42b12a96.png?v=1700063221)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/11_d3211706-bad3-4656-aa38-be1363a72d88.png?v=1700063221)
ACC (Analogue
CAN Converter)
The ACC provides virtually endless data acquisition and system expansion options. ACC adds four freely configurable analogue/digital channels without occupying or modifying the existing system channels.
This plug & play kit with the Solo 2 DL gives you the ultimate track day experience.
It includes the Solo 2 DL, 2 suspension potentiometers, an analogue CAN converter (ACC), a brake pressure sensor, and a bike-specific plug & play cable.
Key Features:
Database with more than 4,000 tracks worldwide | ECU connection cable |
→BMW
→Ducati
→Honda
→MV Agusta
→Suzuki
→Triumph
→Yamaha
Powerful Combination
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim_Solo_2_DL_Wifi_Communication_With_PC.png?v=1614779557)
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Waterproof: IP67
ACC - Analogue channels: 4 channels, 0÷5 V, 12 bit A/D, 200 Hz each
- External power: 9÷15 V Full operation
- Connection: CAN
- Connectors: 2 Binder 712 fem connectors
- Material: PA6 30% glass
- Dimensions: 44.0 x 38.0 x 19.8 mm
- Weight:50 g
Please refer to the Technical sheets in the Downloads Tab for all other diagrams for Solo2 DL.
Below is the pinout drawing for the plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- External CAN cable 2m
- External power cable
- Plug & Play connection cable
- Suspension Potentiometer
- ACC
- Brake Pressure Sensor
Solo 2 DL
The Solo 2 DL can handle an ECU input with a CAN expansion port that you can connect a SmartyCam to.The data you record typically includes RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel).
The kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model.![](https://cdn.shopify.com/s/files/1/0214/9392/files/8_e4d703fc-a51a-423e-a445-797cb1a8be43.png?v=1700063221)
Brake Pressure
Sensor
Brake pressure sensors are used to measure how much force is applied by the rider to the brake, when combined with suspension potentiometers, you can get a greater understanding of your bike setup. Suspension Potentiometer
The suspension potentiometer is used to measure the travel of the suspension forks on your motorbike and therefore helps to understand your suspension setup.![](https://cdn.shopify.com/s/files/1/0214/9392/files/10_a227c6e9-03c8-4246-bccd-931f42b12a96.png?v=1700063221)
ACC (Analogue
CAN Converter)
The ACC provides virtually endless data acquisition and system expansion options. ACC adds four freely configurable analogue/digital channels without occupying or modifying the existing system channels.AiM Solo 2 DL Motorcycle Plug & Play Data Logging Kit
Key Features:
→BMW
→Ducati
→Honda
→MV Agusta
→Suzuki
→Triumph
→Yamaha
![Triumph](https://cdn.shopify.com/s/files/1/0214/9392/files/BikeSetSC3TrackDay-04.png?v=1678793256)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/RS3_Free_Download_abd5190b-6c56-4d42-b25e-949259d85723.png?v=1614357361)
- GPS: 10 Hz
- Memory: 4 GB
Waterproof: IP67
- Connection: CAN
- Weight:50 g
- Solo 2 DL
- ACC
![AiM Solo 2 DL Motorcycle Plug & Play Data Logging Kit - AimShop.com](http://www.aimshop.com/cdn/shop/files/Solo2DLPlug_PlayBikeLoggingKit_ACCUpdated_FloatingV2_CMPR_1445x.png?v=1698140277)
![Triumph AiM Solo 2 DL & SmartyCam 2.2 GP HD Motorcycle Plug & Play Lap Timer Track Day Kit - AimShop.com](http://www.aimshop.com/cdn/shop/files/TriumphAiMSolo2DL_SmartyCam2.2GPHDMotorcyclePlug_PlayLapTimerTrackDayKit3_808c7527-4be3-41e2-9a8c-28000cbd59a2_1445x.png?v=1698140277)
![Triumph AiM Solo 2 DL & SmartyCam 2.2 GP HD Motorcycle Plug & Play Lap Timer Track Day Kit - AimShop.com](http://www.aimshop.com/cdn/shop/files/Solo2DLRearView_withMagnets_2compressed_eb7165da-336a-46f3-8cc7-171fbcdbc680_1445x.png?v=1698140277)
![Triumph AiM Solo 2 DL & SmartyCam 2.2 GP HD Motorcycle Plug & Play Lap Timer Track Day Kit - AimShop.com](http://www.aimshop.com/cdn/shop/files/Solo2DLBottomCompressed_c03a7aa3-eefd-4880-a9ed-287ee811168d_1445x.jpg?v=1698140277)
