MV Agusta F3 675, F3 800, F4 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: MV-PP
- מחיר רגיל
- £67.00
- מחיר רגיל
- מחיר מבצע
- £67.00
- מחיר ליחידה
- לְכָל
MV Agusta F3 675, F3 800, F4 1000 Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for MV Agusta bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
MV Agusta plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
MV Agusta Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the MV Agusta bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following MV Agusta bike models:
F3 675 - From 2012 | F3 800 - From 2012 |
F4 1000 - From 2013 |
Example data protocols
- Below is a pinout drawing for the MV Agusta Solo 2 DL & EVO4S Data Logger plug & play connection cable
- MV Agusta F3 675, F3 800, F4 1000 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for MV Agusta bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the MV Agusta bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following MV Agusta bike models:F3 675 - From 2012 | F3 800 - From 2012 |
