דלג לפרטי המוצר
1 שֶׁל 4
Microtec M222 AiM Solo 2 DL Motocross Plug & Play Lap Timer Kit
SKU: SOLO2-MIC-MX-PP
מחיר רגיל
£535.00
מחיר רגיל
מחיר מבצע
£535.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for Motocross bikes this aftermarket ECU kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Microtec ECU connection cable
This kit has been specifically designed for Motocross bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your bike's ECU will give you all the engine performance information you need to help improve your driving performance.
The Microtec M222 ECU:
Microtec M222 ECU
The Microtec M222 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Microtec M222 plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Microtec M222 Connection Cable
Microtec M222 ECU
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
