דלג לפרטי המוצר
1 שֶׁל 8
M-Sport Ford Fiesta Rally 2 Aim SmartyCam 3 Corsa Kit - MK2 from 2022
SKU: FORD-SM3
מחיר רגיל
£1,150.00
מחיר רגיל
מחיר מבצע
£1,150.00
Compact, Advanced, Precise
Enhance your M-Sport Ford Fiesta Rally 2's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for Mk2 models from 2022.
The NEW SmartyCam 3 Corsa saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Corsa automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times.
FORD Msport 22 Fiesta Rally 2 mk2
Supported Models and years
  • M-Sport Ford Fiesta Rally 2 Mk2
    from 2022
If specifically set by M-Sport, these models feature a CAN data bus accessible to AiM devices through a Deutsch DTM06-2S connector located by/behind the co-driver’s foot plate, labelled CAN3.
smartycam icon
smartycam icon
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
smartycam icon
Quality
smartycam icon
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
smartycam icon
Higher Storage Capacity
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: O recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
smartycam icon
The SmartyCam 3 Corsa Kit seamlessly integrates with the M-Sport Ford Fiesta Rally 2's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 Corsa can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
smartycam icon
Upgrade your M-Sport Ford Fiesta Rally 2 with the AiM SmartyCam 3 Corsa Kit today and experience unparalleled data insights for yourself!
    from 2022
smartycam icon
smartycam icon
Standalone Feature
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
smartycam icon
smartycam icon
Technical Specifications
  • Display resolution: 128 x 128 pixels
  • CMOS sensor: Global Shutter
  • Field of view: 67°, 84°
  • External power: 9-15 Volt
  • Connectors: 3 Binder 712 female 1 USB-C
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Dimensions: 102.2 x 63 x 46.5 mm
  • Weight: 280g, battery included
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for M-Sport Ford Fiesta Rally 2 drivers
smarty cam 3 sport connectors
smartycam 3 corsa pinout
M-Sport Ford 22 Protocol
Channels received by AiM devices configured with M-Sport Ford 22 protocol are:
Channel Name Function
RPM RPM
Vehicle Speed Vehicle speed
Gear FIA Engaged gear
Steering Wheel Steering wheel angle position
Pedal Pos Throttle pedal position
Brake Press Fr Front brake pressure
Brake Press Rr Rear brake pressure
Turbo Speed Turbo speed
Engine Cool Temp Engine coolant temperature
Engine Oil Temp Engine oil temperature
Air Charge Temp Air charge temperature
Exhaust Temp Exhaust gas temperature
Oil Pressure Oil pressure
MAP Manifold air pressure
ALS Cal Anti lag system calibration
  • SmartyCam 3 Corsa
  • USB-C Cable
  • 2m CAN Cable
  • 712 5 Pin Male
  • 4M Can Bus + Integrated 3.5 Female Jack For External Microphone Harness
