Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
- מחיר רגיל
- £67.00
- מחיר רגיל
- מחיר מבצע
- £67.00
- מחיר ליחידה
- לְכָל
Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Panigale plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Ducati Panigale Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
1199 Panigale - 2012-2014 | 1199R Panigale - 2015-2017 |
1299 Panigale - 2015-2019 |
Example data protocols
- Below is a pinout drawing for the Ducati Panigale 899, 959, 1199, 1199R, 1299 plug & play connection cable
- Ducati Panigale 899, 959, 1199, 1199R, 1299 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati Panigale bike models:899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
