Auto Marine Superseal Plug with Seal & Pins Female & Male
SKU: P-SS-1-F
- מחיר רגיל
- £1.25
- מחיר רגיל
- מחיר מבצע
- £1.25
- מחיר ליחידה
- לְכָל
Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint.
Male or Female plug available | Pins and seals |
Water-resistant joint | Suits cables with 0.5mm to 1.5mm cross-section |
Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint. Suitable for cables with a cross-section area of 0.5mm to 1.5mm (approx 20 amps max), they are ideal for applications that require a sure-fitting, weatherproof connector.
Available in male and female options to allow multiple connectors of the same side to be applied (e.g. various types of ends to plug onto a battery charger).
Available in 1, 2, 3, 4, 5, and 6-way, Male and Female options
- Plug housing for receptacle contacts, cap housings and tab contact varients
- Silicone rubber seals
- Suitable for powertrain, security and body & chassis systems
- Male & Female available
- 1, 2, 3, 4, 5 ,6 Pin available
- Auto Marine Super Seal Plug with pin and seals
Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint.Key Features :
Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint. Suitable for cables with a cross-section area of 0.5mm to 1.5mm (approx 20 amps max), they are ideal for applications that require a sure-fitting, weatherproof connector.Available in male and female options to allow multiple connectors of the same side to be applied (e.g. various types of ends to plug onto a battery charger).
