דלג לפרטי המוצר
1 שֶׁל 3
BMW S1000RR & S1000RR HP4 AiM Solo 2 DL Plug & Play Cable
SKU: BMW-PP
מחיר רגיל
£67.00
מחיר רגיל
מחיר מבצע
£67.00
The AiM ECU plug & play cable has been specifically designed for BMW bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
BMW plug & play cable 7 pin - 712 male binder connection
BMW Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the BMW bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following BMW bike models:
S1000RR - 2009-2014 S1000RR - From 2015
S1000RR HP4 - 2013-2014
Example data protocols
  • Below is a pinout drawing for the BMW Solo 2 DL plug & play connection cable
  • BMW S1000RR, S1000RR HP4 Plug & Play connection cable
