דלג לפרטי המוצר
1 שֶׁל 4
Aprilia RSV4 RR/RF, RSV4 1100, Tuono V4 RR Factory AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-AP
מחיר רגיל
£710.00
מחיר רגיל
מחיר מבצע
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Aprilia this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Aprilia ECU connection cable
This kit has been specifically designed for Aprilia bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Aprilia ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Aprilia bike models:
Aim Aprilia Motorcycle
Aprilia RSV4 RR/RF - From 2017 Aprilia RSV4 1100 - From 2019
Aprilia Tuono V4 RR/Factory - From 2017
The Aprilia ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Aprilia plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Aprilia Connection Cable
  • Bracket
  • 1 Allen screw with a rounded head M8 x 45mm
  • 1 toothed washer
  • 1 rubber dowel
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 1 toothed washer
  • 1 rubber dowel
