Aprilia RSV4 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: APR-B
- מחיר רגיל
- £42.00
- מחיר רגיל
- מחיר מבצע
- £42.00
- מחיר ליחידה
- לְכָל
The AiM Aprilia motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Aprilia bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Please Note: The bracket is only compatible with RSV4 original triple clamp.
Also available is our Aprilia plug & play cable for the following bike models: (Sold Separately)
Aprilia RSV4 RR/RF - From 2017 | Aprilia RSV4 1100 - From 2019 |
Aprilia Tuono V4 RR/Factory - From 2017 |
Example data protocols
- Specifically designed Aprilia RSV4 bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
The AiM Aprilia motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
Also available is our Aprilia plug & play cable for the following bike models: (Sold Separately)Aprilia RSV4 RR/RF - From 2017 | Aprilia RSV4 1100 - From 2019 |
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
