דלג לפרטי המוצר
1 שֶׁל 1
AiM Weld on Tab for Dash Bracket
SKU: UP-TAB
מחיר רגיל
£3.00
מחיר רגיל
מחיר מבצע
£3.00
Weld on Tab
A simple weld on the chassis tab to facilitate dash and button mounts.
Key Features:
  • Weld on a tab mount
  • 3mm stainless steel
  • Free race studio 3 download
Weld on Tab
A simple weld on the chassis tab to facilitate our modular dash/button mounts.
3mm Mild Steel
Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays/buttons/dash / lap timer/shift lights.
Aim Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today.
Unlock your potential
    • 3mm mild steel
    Technical Sheet
    Weld on Tab
    Key Features:
    Weld on Tab
    3mm Mild Steel
      • 3mm mild steel
      Whats In The Box
      Technical Sheet
