דלג לפרטי המוצר
1 שֶׁל 2
KTM Plug & Play AiM Taipan Motocross ECU Kit
SKU: C-ECU-KTM
מחיר רגיל
£635.00
מחיר רגיל
מחיר מבצע
£635.00
AiM Taipan ECU Plug & Play Kit For KTM Motocross Bikes
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 sec for turning the spark ON!
UC Bridge
Tuner License :
Taipan ECU Connections
Aim Handlebar Switch
Below shows a functional diagram of products that can be added to the Taipan ECU:
AiM Taipan ECU Plug & Play Kit for KTM
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for KTM
Traction Control
Launch Control
UC Bridge
Tuner License :
  • Waterproof: IP67
  • Weight: 260g
Video
