AiM Solo 2 DL CAN / RS232 2M External Power Cable Motorcycle
SKU: SOLO-K3-L-MC
- מחיר רגיל
- £42.00
- מחיר רגיל
- מחיר מבצע
- £42.00
- מחיר ליחידה
- לְכָל
The AiM CAN/RS232 2m external power cable connects your Solo 2 DL to your ECU wiring.
7 pin - 712 male binder connection | 6 non-terminated wires |
Suitable for Solo 2 DL | |
RS232/CAN External Power Cable
The AiM RS232/CAN 2m external power cable connects your Solo 2 DL to your ECU.
This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RPM cable.
- 7 pin - 712 male binder connection
- 2m length cable
- Free cables:
- White - CAN+
- Blue - CAN-
- Red - 9-15DC
- Blue - ECU RS232 TX
- White - ECU RS232 RX
- Black - GND
- Both blue wires have a tag identifier, stating the connection type.
- Solo 2 DL RS232/CAN External Power Lead
The AiM CAN/RS232 2m external power cable connects your Solo 2 DL to your ECU wiring.Key Features :
The AiM RS232/CAN 2m external power cable connects your Solo 2 DL to your ECU.This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RPM cable.
- 2m length cable
- Free cables:
- White - CAN+
- Blue - CAN-
- Red - 9-15DC
- Black - GND
