דלג לפרטי המוצר
1 שֶׁל 4
AiM SmartyCam GP HD 2.2 & 3 ECU CAN & 3.5mm Female Jack Plug for External Microphone & External Power Harness
SKU: SM-ECU-EM
מחיר רגיל
£80.00
מחיר רגיל
מחיר מבצע
£80.00
Aim SmartyCam 2.2 ECU CAN Harness
External power lead to allow battery connection 12v.
Key Features:
  • Constant 12v power supply
  • 712 7 pin binder
  • 3.5mm female jack plug
  • Free race studio 3 download
AiM SmartyCam 2.2 ECU CAN Harness
The AiM SmartyCam GP HD 2.2 ECU CAN, power and integrated 3.5mm female jack plug cable has Motorsport engineered grade cable and fittings so it is able to with stand the harshness of Motorsport.
The power cable is a useful accessory for when you want the reassurance of having the camera powered from your vehicles 12v system.
The female 3.5mm jack allows you connect to an on-board radio to intercom system (additional cable may be required depending on your radio / intercom).
Provides direct battery power supply to an AiM SmartyCam 2.2 camera
Featuring a CAN high and CAN low connection inputs for the ECU
Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash as the power will be supplied to the camera through the CAN connection.
AiM Technologies are committed to supplying professional engineers quality products. Our cables and accessories are well engineered and designed for rigours Motorsport. Our racing components are amongst the best in the industry today.
Unlock your potential
Technical sheet
Key Features:
  • 712 7 pin binder
Technical sheet
