AiM SmartyCam GP HD 2.2 3.5mm Female Jack Plug for External Microphone Harness
SKU: SM-EM
- מחיר רגיל
- £40.00
- מחיר רגיל
- מחיר מבצע
- £40.00
- מחיר ליחידה
- לְכָל
Aim SmartyCam GP HD 2.2 External Microphone Cable
SmartyCam GP HD 2.2 1m 3.5 External Female Jack for Microphone
Key Features:
Aim SmartyCam GP HD 2.2 Cable
The female 3.5mm jack is ideal if you want to connect the SmartyCam to your intercom system. The cable is 1 metre in length and plugs directly into the recording unit 7 pin 712 binder connection labelled ECU-Mic. Please Note: This cable is only compatible with the Rev 2.2 SmartyCam GP HD.
AiM Technologies are committed to supplying professional engineers with quality products. Our cables and accessories are well engineered and designed for rigours Motorsport. Our racing components are amongst the best in the industry today. |
Unlock your potential |
Key Features:
The AiM SmartyCam GP HD 2.2 Jack Connection enables you to add an external microphone to your SmartyCam GP HD 2.2 Rev only. The female 3.5mm jack is ideal if you want to connect the SmartyCam to your intercom system. The cable is 1 metre in length and plugs directly into the recording unit 7 pin 712 binder connection labelled ECU-Mic. Please Note: This cable is only compatible with the Rev 2.2 SmartyCam GP HD. |
