Potentiometer Replacement Pop End Fitting
SKU: SUS-POT-END
- מחיר רגיל
- £8.50
- מחיר רגיל
- מחיר מבצע
- £8.50
- מחיר ליחידה
- לְכָל
Replacement pop end joint fitting for the suspension potentiometer.
Replacement pop end fitting | Spare or replacement parts |
The Potentiometer pop end fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Pop End Fitting Replacement Supplied.
- Replacement Potentiometer Pop End Fitting
- 1 x Pop End Fitting Potentiometer Replacement
Replacement pop end joint fitting for the suspension potentiometer.Key Features :
The Potentiometer pop end fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.Use as a replacement or spare part.
