דלג לפרטי המוצר
1 שֶׁל 1
AiM PDM08 / PDM32 6" Dash Mount
SKU: DISPLAY-6-M
מחיר רגיל
£25.00
מחיר רגיל
מחיר מבצע
£25.00
PDM08 / PDM32 Dash Mount
AiM PDM08 / PDM32 6" Dash Mount Modular Steering Assembly.
  • Suitable for 6" PDM08, PDM32 dash
  • 2mm thick stainless steel
  • Free race studio 3 download
This dash bracket has been designed to fit the PDM08 & PDM32 to the steering wheel column.
Due to the size of the dash, this bracket will probably be used with our single mount centre hub on the steering column or our chassis weld-on and bolt-on tabs, it will also work without steering wheel mounts if you prefer.
Optional Weld on the tab for your chassis or steering column.
Made from stainless steel with a raw finish it has interchangeable components to facilitate the mounting of displays, buttons, dash, lap timers and shift lights.
    • Stainless Steel
    • 2mm Thick
    • AiM PDM08 / PDM32 6" Dash Mount
    User Guide
    Technical sheet
      • Stainless Steel
      • 2mm Thick
      What In The Box
      User Guide
      Technical sheet
