AiM PDM32 Pre Assigned 3m Grey Connection Harness
SKU: PDM-L-G
- מחיר רגיל
- £225.00
- מחיר רגיל
- מחיר מבצע
- £225.00
- מחיר ליחידה
- לְכָל
AiM PDM Pre Assigned 3m Grey Connection, Harness
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits.
Suitable for PDM32 | Colour coded & tagged cables |
Provides easy installation |
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits. Each of the wires on the harness is colour coded and tagged to help provide an easy installation.
Suitable for the PDM32
3 metres in length
Pre-wired connector for the easiest of installations
- AiM PDM pre-assigned 3m, Grey Connectin Harness
- PDM Pre-assigned Grey Connector Harness
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits.Key Features :
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits. Each of the wires on the harness is colour coded and tagged to help provide an easy installation.Suitable for the PDM32
3 metres in length
