דלג לפרטי המוצר
1 שֶׁל 3
AiM PDM32 Pre Assigned 3m Black Connection Harness
SKU: PDM-L-B
מחיר רגיל
£225.00
מחיר רגיל
מחיר מבצע
£225.00
AiM PDM Pre Assigned 3m, Black Connection Harness
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits.
Suitable for PDM32 Colour coded & tagged cables
Provides easy installation
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM32 advanced power distribution module data logger kits. Each of the wires on the harness is colour coded and tagged to help provide an easy installation.
Suitable for the PDM32
3 metres in length
Pre-wired connector for the easiest of installations
  • AiM PDM pre-assigned 3m, Black Connectin Harness
  • PDM Pre-assigned Black Connector Harness
3 metres in length
