דלג לפרטי המוצר
1 שֶׁל 2
AiM MyChron Magnetic Lap Receiver
SKU: S-MG
מחיר רגיל
£125.00
מחיר רגיל
מחיר מבצע
£125.00
This magnetic lap timing receiver is compatible with the Aim MyChron lap timers and directly replaces the sensor supplied initially with the MyChron4. You can also use it with the MyChron5 if GPS is not available.
Magnetic lap receiver 712 - 4 pin binder connector
Suitable for MyChron4, MyChron5
The sensor triggers the timer when it passes over the magnetic timing strip fitted to most kart tracks.
Replacement sensor for MyChron4
Compatible with MyChron5
Triggers lap times from the magnetic strip found in kart tracks
  • 712 - 4 pins Binder Connector
  • 1 x AiM Magnetic Lap Receiver
