Aim MyChron Kart Racing Steering Wheel Red/Black
SKU: M5-W-R
- מחיר רגיל
- £165.00
- מחיר רגיל
- מחיר מבצע
- £165.00
- מחיר ליחידה
- לְכָל
The Ideal Kart Racing Steering Wheel
The Aim MyChron Kart Steering Wheel provides an ideal solution for mounting your MyChron 5S/5S 2T and MyChron 6/6 2T Lap Timer.
Lightweight but rugged and ergonomic, it allows you to put your MyChron in the best position right in front of you.
Steering Wheel Key Features
Design
The MyChron Steering Wheel has an anodised aluminium frame covered by Koram Nabuk and Shammy Leather, with a flat bottom and a curved top. The Nabuk coating around the sides maximises grip, bringing total control of the kart in your hands.
Measuring 340 x 320mm and supplied with a mounting bracket.
Options
Available in red/black with 3/6 holes, the MyChron Steering Wheel is a "must-have" tool for all MyChron owners.
Please Note: The MyChron Lap Timer is not included in the kit.
These are just some of the expansions compatible with Aim products.
Design
Options
- Diameter: 340mm
- Weight: 600g
- Versions: Three-hole or Six hole
- Chassis: Anodised Aluminium
- Finishing: Koram Nabuk and Shammy Leather
What's In The Box
- Aim MyChron Steering Wheel
- MyChron Mounting Bracket
