Aim MXS 1.3 Strada IVA Compliant TFT Kit Car Dash Display
SKU: MXS-IVA-CAN
- מחיר רגיל
- £1,200.00
- מחיר רגיל
- מחיר מבצע
- £1,200.00
- מחיר ליחידה
- לְכָל
An IVA Compliant Digital Dash Display
IVA compliant displays are essential for road legal OEM kit cars and racing vehicles in the UK, ensuring compliance with the Individual Vehicle Approval (IVA) standards. These digital dash displays offer compliance with road legality standards, simple plug & play installation and connectivity with the vehicle's ECU to enhance performance - all possible by the IVA-specific second harness that comes with the display kit.
Dash Key Features
Why Choose The Aim MXS 1.3 Strada IVA Compliant Dash Display Kit
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle's ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.
As well as the standard 14 pin wiring loom included in the kit with a choice of CAN or OBDII, K-Line the kit also comes with an additional 23 pin loom which has pre-configured connections for all the main relevant electrical items in your vehicle such as oil, temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
With CAN Output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
Digital Display
Pre-Configured Pages
Flexible Shift Lights & Alarms
The ten multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS option. You can choose the conditions and colours, select a solid arm or flashing one and the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.
Camera Inputs
Two analogue camera inputs are available to switch your display into a mirror camera through a pushbutton command or event management. The camera is sold separately.
Pin Harness
The MXS 1.3 Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the vehicle's ECU using the OBDII port or directly to the ECU through the CAN channel.
These are only some of the items that can be added to our MXS 1.3 Strada to increment the performance and the data acquired.
With Race Studio 3, you can also analyse all data recorded by MXS 1.3 Strada and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Dash Key Features
Digital Outputs
Digital Display
Camera Inputs
Pin Harness
Aim MXS 1.3 Strada IVA Compliant TFT Dash Display Plug & Play Kit
- Display: 5" TFT
- Contrast: 600:1
- Ambient Light Sensor: Yes
- CAN Connections: 2
- Second CAN: Yes
- Body: Anodized Aluminium
- Power Consumption: 400 mA
- Dimensions: 169.4 x 97 x 23mm
- Weight: 480g
What's In The Box
- MXS 1.3 Strada
- USB Cable
- 14 Pin Standard Wiring
- IVA Loom
- Aim Sticker
