AiM MXP 1.3 6" TFT Ducati Logger with CAN Connection
SKU: MXP-DUC-KIT
- מחיר רגיל
- £2,190.00
- מחיר רגיל
- מחיר מבצע
- £2,190.00
- מחיר ליחידה
- לְכָל
AiM MXP Ducati Logger with CAN Connection
The MXP Ducati dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.
6" TFT display | GPS Module |
Two Digital Outputs
Flexible Alarms
CAN output
GPS Module
Pin Harness
- Display: 6" TFT Display
- Contrast: 600:1
- Ambient Light Sensor: Yes
- CAN connections: 3
- Second CAN: Yes
- Body: Anodized Aluminium
- Power Consumption: 400mA
- Weight: 640g
- MXP Dash Logger
- 37 Pin standard harness
- GPS Module with cable
- USB Cable
The MXP Ducati dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.Key Features :
The MXP TFT 6" wide colour Dash Logger is fully configurable and suitable for many different Motorsports. It has been designed to acquire and display data coming from the ECU. The internal accelerometer and GYRO, GPS Module (included in the kit), analogue/digital inputs and predefined math channels. Performance and data acquired can also be incremented by adding up to eight expansion modules.Easy Connection
Two Digital Outputs
With a high contrast 6" TFT display which is fully configurable. You can create and customise pages/displays to suit your requirements. Swapping pages can be managed by pushing on or two pushbuttons.Two analogue camera inputs are available, to switch your display into a mirror camera, through a pushbutton command or event management. The camera sold separately.
Flexible Alarms
The MXP has ten configurable RGB LEDs. You can choose the conditions and colours. Select a solid alarm or flashing one and the flashing frequency, you can choose to have an accompanying text message and set the alarm priorities.With integrated shift lights you can choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to suit your requirements, and for each unique gear when required.
CAN output
The GPS Module connected via CAN to the MXG makes lap time calculation and track position analysis easy. With 4000+ worldwide tracks already stored with the start and finish line coordinates you will have no problem when you're on the track. As soon as the MXP is turned on the GPS Module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not on the database, you can easily add the start/finish line coordinates to the MXP via a PC before you go to the track using our Race Studio 3 software.The GPS Module is available in 1.3m or a roof version in 2m.
Pin Harness
The 37 pin harness comes standard in the kit, should you need more data you can add our 22 pin harness as an optional extra.Expand Your System
These are only some of the items that can be added to our MXP for incrementing the performance and the data acquired.Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded by MXP and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.Technical
- Contrast: 600:1
- Second CAN: Yes
- Weight: 640g
- MXP Dash Logger
- USB Cable
