דלג לפרטי המוצר
1 שֶׁל 3
AiM Cylinder Head Thermocouple 14mm K Type Motorcycle
SKU: S-T-CH-X05SOT14A4516MS
מחיר רגיל
£70.00
מחיר רגיל
מחיר מבצע
£70.00
The AiM cylinder head thermocouple sensor for motorcycle allows you to measure cylinder head temperature when the sensor is placed between the spark plug and cylinder head.
Measure cylinder head temperature  Thermocouple male fitting
Wide temperature range 2 pins
The AiM Cylinder Head 14mm thermocouple features a turn in its lower part for an easier installation/uninstallation; it has to fit between the spark plug and the cylinder head.
To keep the sensor in contact with the cylinder head, remove the washer from the plug when installing the thermocouple.
While running the thermocouple cable along with the chassis, keep it as far as possible from other lines (like RPM or lap receiver ones) to minimize cable interferences.
Please note: before screwing the spark plug cable back ensure that the sensor is firmly fixed to the cylinder head. While screwing it, minimize the thermocouple movements to avoid damage to the sensor.
Temperature range of 0-300°c
Sensor cable length 400mm
  • Temperature working range: 0-300°C
  • Cable sensor length: 400mm
  • Cable Type: Compensated
  • K Type thermocouple
  • AiM Cylinder Head 14mm Thermocouple Temperature Sensor
